Hello All,
First of all I am very grateful to have found this forum and have already signed up as a member.
Second, I made as extensive a search as possible, before posting this, to see if I could find the answer in previous responses, but could not. Hence this new post.
I am helping a friend to get her Beomaster 7000 / Beogram CD 7000 onto operation. It was used for years by other family members until about four years ago, then put into storage. I have found a Beo4 that must have been used with it, as no other remote is present. However, the Beo4 had no betteries in it (good thing, actually!) but now that I have but in fresh batteries, the remote is not "talking with" the 7000 units. I downloaded the PDF owner's manual for the Beo4 and it tells me to press LIST, then choose CONFIG?, but this choice does not appear. All I can see is OPTION?, ADD?, and REMOVE?
My intention is to program the remote for "audio systems other than 9000" but all of this is very confusing, and all I am capable of is doggedly following the instructions in the PDF of the owner's manual. Since I cannot seem to find CONFIG? I thought I would post here, either for an answer, or perhaps someone can direct me to a url that has straightforward instructions about how to do the programming.
With thanks, Bruce (and Katey, whose gear this is)
