beo4 navigation/beo5
Need help, just updatd to the latest beo4 with navigation wheel. PUC is version 2 and it works fine. but now it does not work with my Beo5. what to do???
Maybe you have to re-program your Beo5?
Have you already tried this?
No,will have to pay my dealer a visit on Monday.
.......or you can do it your self during the weekend!!!
I don't understand much off the beo5 configuration program : (
Not that difficult I would say. But if you don't feel comfortable with it, it's better to leave it to your dealer.
Sometimes things get nasty with this software!!!!
Using Config Tool 3.87 you just change from "No navigation button" to "Navigation button Mode 1". You will find it in section "Choose products". Click on your videomaster (BV7 ?) and the settings menu will display: Stand - Modules - Sources - Navigation buttons...
Stefan
Thanks for the help. I will pay my dealer a visit on Monday, I need a new masterlink cable anyway.
