Beo4 MkIII and Phono?
Hi Beoworlders,
Is there any way to operate a Phono with the Beo4 MkIII?  I'm using with BC9500 and BG9500...?
Steve
You need to ADD Phono to your list button as described in the manual.
Like this...........
Press Stby and List together. Display should say Add?  If not then List until it does. Then Go
Press List until Phono displayed. Press Go
To operate just press List until Phono displayed and then Go. Your deck should now start.
N.Radio uses the same codes as well and hence using this in List will also operate the Beogram.
Thanks, got it.  Shame they dropped Phono off the List..
