Hi all,
I have a BV7 and a BL3500 located in two different room. The rooms are however in open connection. I have not had any problems operating the BV7 from a BEO4 in one of the rooms without the BL3500 reacting to the IR signal in the other room and the other way around. But after getting a BEO5 both units quite often react to the IR. I guess the BEO5 send much stronger IR the the BEO4, and thats nice but also can create problems.
A way to aviod this cound be to set the BL3500 in "link" mode (option 6 i think), but then i have to press "Link" + "Radio" etc. when operation the BL3500. As i'm only using one specific BEO4 to operate the BL3500 it could be a solution if it's possible to set the BEO to permanet send "Link" mode signals. Any one knows if this is possible? and how?
Regards,
Ken
