I have a Beo4 DTV version. This is not like the rest I have, this one is VERY directional.
Not a distance thing but you have to point it directly at the target. The rest of by Beo4s you can point anywhere you like and it works.
So I changed the batteries, still the same.
Is this a fault or I was just wondering if there was a dealer setting for use in stores to make the Beo4 very directional or set to reduced power etc?
Only thing I've seen is those 'range reducer' plastic caps being used so I'm guessing that my Beo4 is simply faulty?
Second question - probably another simple answer - but does Beolink 7000 work in two-way mode with Beomaster 6500?
