beoboehm wrote:
Hey fellow BeoHeads,
I just got a Beo4 remote with a used device I just bought.
The thing is, that it does not work fine with any B&O product I own, including the one it came with.
The Beo4 display works as it should and the IR blasts can be seen throng an iPhone front camera.
It does not work at all with my Beosound Century or my Beocenter 2.
It kind of works with my Beosound 1 (old) but only when I hold it not further than 10cm or so away from the BS1.
I am confused because I can clearly see the IR in the camera.
Can someone solve this mystery?
Thanks in advance
Carlo
Hi and welcome to Beoworld.
The Beo4 may be in link mode (but this doesn't explain why it works up close with the BS1)
Anyway, see the following:
Follow the procedure below the make one of the Beo4's a link remote .
Standby + List together
Press List till CONFIG appears
Enter 2002 , the display should read LINK ON
Press Exit
This remote will now only work a Link device and will not interfere with others and visa versa . To reset to a normal remote remover and replace the batteries.
I think that you repeat the above procedure to get the Beo4 out of 'link mode', whereupon the display should show 'Link Off' at the appropriate point.
Good luck!
