Added a WD HD Live unit to the BV10 and works very well together with the PUC; only function that I've not found on the Beo4 remote is how to pause a movie or video clip. Using STOP does what it should but also exists the movie and one has to resume the video to continue; but would like to have make use of a simple pause function.... anyone has a quick ansers to this one?
Beo4 controls for WD HD Live [SOLVED]
GO?
command for pause on beo4 press stop. to continue go
malcolm
Hi Malcolm,
Well, pressing STOP is full stop and existing to WD file browser GUI; so from my perspective an ugly way of implementing pause which should be freezing the image.
So that means that when using fast forward (blue button) the only way to resume normal speed seems to be pressing STOP, existing the clip, and resuming it by pressing GO when being at file browser GUI. Pressing GO when doing fast forward does not resume normal speed... honestly is their a way of getting B&O to update the PUC profile to at least include a functional pause feature?
Quick update with a solution on my initial question on how to pause a running video clip. I noticed that when clicking GO when viewing a video clip it brings up the time line/info bar fΓΆr the clip; so what else can one do? Well, clicking GO once again actually paused the playing; so the solution is simply to press GO two times to pause the video clip. And clicking GO two times to resume; one time to view the time/info bar and one time more to resume.
Very good idea to put "Solved" in the subject line π
Glad you found a solution.
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
