I know the info is on the site somewhere but I will be blowed if I can find it. Need a list of the comands available once set up with STB controller.
Thanks in advance
Jonnie
Thanks in advance
Jonnie
Jonnie,
I think the following is what you are looking for:-
Perfect Keith. Always rely on you to come up trumps, thankyou.
Jonnie
Hi Keith,
Just thought. What about the centre wheel functions LEFT RIGHT UP DOWN and SELECT? Also the PAUSE and PLAY buttons?
Jonnie
Does anyone know the commands for a Virgin V+ box?
I have asked this on another thread but no one has replied.
I would also be interested as I have just got Virgin+ box
Peter/Anyone!
I'm having problems with a STB-C attached to Beovision 8 and (Amstrad?) Sky+ box.
The installation is new and I've already had the shop back once since the installation to get the STB-C working. Initially there was very erratic and poor response to the Beo4. This problem was thought to be that the IR emitter was too strong! Indeed placing a piece of paper between the emitter and the sky IR receiver has worked very effectively in getting the system to perfectly respond to up/down arrows and the numerical part of the Beo4 keypad.
However, none of the central buttons (FF, RWD etc) appear to work. Additionally 'Go' doesn't appear to act as 'Select', but instead goes straight to playing the last programme recorded. I'm also unsure how to Record a programme - Record on the Beo4 doesn't seem to do anything.
I'm loathe to call the shop out again without checking I'm not being an idiot and misunderstanding how to correctly operate the system.
Thanks in advance for any helpful suggestions.
AP
