Beo1
"On BC1-2004 I select source with the beo4 on Bc1 -2001 all could be accessed by beo1."
What happens with BC1-2004 when you press MENU on Beo4?
"So there must be a software or hardware difference between Bc1-2001 and BC1-2004 ?"
Maybe. Sorry, I can`t help with BC1, because I don`t own one. I just got a Beo1.
"btw as I reprogrammed the beo1 towards beo4 commands. Will it still be possible to use it on the BC1 -2001 as it did before reprogramming ?"
I don`t think so. But try and let us know....
"And if not how is it reversable ?"
Usually it`s the same sequence once more (think of Beo4 reprogramming for LINK codes), but I can`t test it, because I don`t have a BC1 as said before.
Stefan
Hi to all!
Do you need a B&O TV /Masterlink for use BEO1 with Standardcodes to Control BS9000 or BS4.
I´ve tryed to control a BS4 and a Century with Beo1 without an B&O TV but it doesn´t work.
Can anybody help me?
Thanks a lot
Greets Sven
Beo1 has no source buttons. So you have to select source with Beo4, and you can navigate with Beo1. Left - Right - Up - Downn - Play - Stop - Volume/up-down - Standby - should work. In my setup GO activates DTV when everything is in standby.
Stefan
It works!
I had tried a while ago and I couldn't get it to work. I noticed this thread again and thought I 'd give it another go. I replaced the batteries and tried again and again (about 25 times) and then suddenly the BL 3500 in the kitchen came on.
Strange thing is that it doesn't work in the main room where I have the BS9000 but it works fine in the other rooms. Not fussed though as it will be used in the guest room.
Thanks heaps; you've made my day.
Peter
I try try, but it will not work, perhaps its really that you need a B&O TV??
I just checked my Beo1:
It doesn`t work with my BS7000, BC9500 (both 2 way), BM3300, BS Century (both 1 way).
It works with my BV7-40 MKIII, BC6-26, BV6-22, Lintronic box.
It`s also possible to control the BS9000 (in OPT.0) via BV7-40.
Looks like you are right. Beo1 only works with Beovisions....(?)...strange.
Stefan
I don't have a B&O television.
The Beo 1 works fine in link rooms but won't control the BS9000 direct in the main room.
Strange....
Stefan
Ok a bit late but never the less,.....I tried to operate the BC1 -2001 with the reprogrammed beo1 and it still works.
rec buttons were not tested as there is no recordable medium attached.
I just got hold of a Beo1, tried this with mine and after a few attempts it worked perfectly and will now control my BV3.  Only thing I can't do is switch on the digibox via the STB controller.
A very useful thread for Beo1 owners!
