Is it possible to use Beo1 to other than beovision1 ....? it is possible to configure it so you get some features to work on other Bang and Olufsen equipment
Beo1
As far as I am aware it only works on early BV1 and BC1 and it is not possible to re-configure it.
As said before I have reprogrammed my Beo1 to standard Beo IR codes. So I can use it with my BV7-40 MKIII, BS9000...
All buttons are working like Beo4 buttons.
See : http://forum.beoworld.org/forums/t/13515.aspx
Stefan
Stefan,
I can´t get it to work.
Would be nice to be able to use the Beo1, not just have it standing as an artpice:-)
I´m pressing Standby+Display+Stop at the same time then
pressing Stop and holding then pressing double arrow right, and release the two
then pressing Display once
Is this the right way to do it???
Stefan.
Marvelous trick,
it works!
Hebo, you got the instruction right.
Stefan,
Hi Hebo,
yes you got that right. Strange, some people got it to work, some did not.....??
Mine is working like a Beo4 - but no colored buttons, no EXIT...
Stefan
I tried but unfortunately does not work
Claudiu,
we probably have greater luck in other areas😁
No way...
I know this might not be the most manly thing to say, but I love you guys. I have had my Beo1 ever since my parents BV1 got stolen in 2002, and I have just had it standing as a piece of art, and even though several people have asked me if they could buy it, I have kept it because I think it is so beautiful designed. That I can actually use it again is fantastic. This has really made my evening 😁
At first I couldn't get it to work, because I hadn't seen the last "display" button press, but now it works fine on my Avant. I can't believe it didn't do this as standard, but that it is still capable.
Cheers guys 🤒
Now I just wait for
