anyone want to tell me how to do it as av plugged it all in and nothing i have even pressed FN and F4 but my screen on my laptop dont even switch over. so can anyone help?
Thx
Macs.
Thx
Macs.
how does one do this?
i havnt a clue i dont use pc am a mac guy so i dont know how to use this thing
So, the Laptops graphics card is fine, it is a ATI Radeon Xpress 1100 with shared VGA memory.
It has a compatible S-Video output which is switched with "Function" F4 as you have stated.
By pressing and holding the "Function" key and press F4 you should toggle between laptop screen and external display or dual display.
You previously stated that when you hit "Function" and F4 the laptop screen did not change, this may be because it is in dual display mode which is the default.
Check the AVANT has Camcord on the display and if it does not then bring it up from the Beo4. Normally it would change automatically when a signal appears on the S-Video input. Is Camcord on the AVANT display ?
