beo sound moment
Typical. I have none of the above mentioned problems.
My Moment uses the speakers which are connected to my BV9 through the NL/ML converter. In the linkmenu the BSM showes a playing Core,Essence and M5. All NL devices are shown in the setupmenu.
So, what’s the difference.
Lyle, if you're listening: please push out a rollback so we can go back to the previous software version. After that, I'll be turning my auto-updates OFF.
Lyle,
To be clear here: we are no longer your beta testers. We should not need to fill out "a form" to report this issue. (As you just emailed me asking me to fill out a form.) We finally thought we had a stable product. Now, it no longer isn't after your software update. Fortunately, I'm still under warranty. I'm prepared to contact my dealer about this for a refund if this isn't sorted ASAP.
Mine has been rock solid prior to and after the update, very odd
