beo sound moment
Well I guess in life we all have our own personal opinons, I myself like the moment alot.
So my question is there away to connect wireless headphones with the moment if so does anyone know which ones?
I would think being functional and reliable would be conditions for liking it alot, or did I miss a post?
It works pretty well now and has done for the last year or so.
But it’s not a very good product by design though.
There is not.
Moment is not sending anything over Bluetooth. Just receiving.
Did you get your problems sorted?
Well after 4 weeks of being sent places I finally get an answer, and that answer is a total replacement of the jukebox costing 520 euros. Wow the shop in the uk did a good one on me. My trust in buying second hand from a b and o shop has gone. The repair shop in Germany, because of the model had to be sent to Germany stated the untit had been drop sometime in it life. Not by me.... but the oak side had a mark i put that down to wear and tear. Anyway the choice is pay the money or have a door stop. Im going to write to the citizens advice to check what my rights are. Ive contact the b and o shop in the uk but they dont respond. Seems like these days customer service is not that important to some shops (not all) but some.
Unfortunately, my Moment just experienced exactly the same issue. That is, my Moment was working fine when I unplugged the power cable of the Soundheart with the Jukebox still on the Soundheart.  After a couple of weeks with the Soundheart being without power, I went to resetup the Moment.  The Jukebox was unresponsive, but I assumed it was discharged so I plugged in the power cable of the Soundheart.  After days of trying to charge the Jukebox, the Jukebox would not come back to life (although the Soundheart appears to be functioning properly).  That is, the screen remains dark and the Soundheart (as far as I can tell) does not see the Jukebox.  I believe I’m a month or so out of the 3 year warranty, so it looks like I’ll have to spend $800 to replace the Jukebox.
Severed_Hand_of_Skywalker wrote:
Hate to be the cranky realist here but the moment is the worst product B&O has ever made.
The moment can't do anything an iPad with a cheap NAS/Sonos can't do, for 1/10th the cost. I'd suggest getting your money back if you can.
The encore tops the list i think
So sorry for all you with no luck on BSM.
I did want to purchase BSM some time ago
That is why i still have BS9000 mk3 FM, CD on aux + all moden add-ons on the music server.
intrernet radio, streaming spotify, deezer, tidal , 3tb music disc, ripping,yoube , can be wisa with USB support...ect...
Hi END D/A conveter that make total difference in music. And i think TIDAL is best option for hi res. music streaming.
No problems in 3 years.
I use an iPad now
As you probably know, I use - and have used for a while - an iPad (Mini) too.....with a vertical stand.
Great stand there - where did you get that?
It seems to have just the right angle for a desktop.
