beo sound moment
Well I guess in life we all have our own personal opinons, I myself like the moment alot.So my question is there away to connect wireless headphones with the moment if so does anyone know which ones?
I would think being functional and reliable would be conditions for liking it alot, or did I miss a post?
There is not.Moment is not sending anything over Bluetooth. Just receiving.Did you get your problems sorted?So my question is there away to connect wireless headphones with the moment if so does anyone know which ones?
Unfortunately, my Moment just experienced exactly the same issue. That is, my Moment was working fine when I unplugged the power cable of the Soundheart with the Jukebox still on the Soundheart. After a couple of weeks with the Soundheart being without power, I went to resetup the Moment. The Jukebox was unresponsive, but I assumed it was discharged so I plugged in the power cable of the Soundheart. After days of trying to charge the Jukebox, the Jukebox would not come back to life (although the Soundheart appears to be functioning properly). That is, the screen remains dark and the Soundheart (as far as I can tell) does not see the Jukebox. I believe I’m a month or so out of the 3 year warranty, so it looks like I’ll have to spend $800 to replace the Jukebox.
Hate to be the cranky realist here but the moment is the worst product B&O has ever made.
The moment can't do anything an iPad with a cheap NAS/Sonos can't do, for 1/10th the cost. I'd suggest getting your money back if you can.
The encore tops the list i think
So sorry for all you with no luck on BSM.
I did want to purchase BSM some time ago
As you probably know, I use - and have used for a while - an iPad (Mini) too.....with a vertical stand.
Great stand there - where did you get that?
It seems to have just the right angle for a desktop.
