Beo Remote One
Hi All,
I've just had an Avant 55 installed, very happy with it.
Does anyone know which button to use on the remote to record on sky though? it's the only thing I can't figure out.
Paul
I have sky  on my beo4 press menu then 8  an r will then be against the programme you are going to record
cheers
malcolm
Hi Paul
I'm just having the same problem with my Beoremote 1 and Sky+HD on my BV14-55. Did you ever get an answer from anyone. Thanks
There should be an overlay menu (from the PUC), when you press Menu - this should show you which button/button combination to use.
Or you can do menu 8 I think
