Hi All,
I've just had an Avant 55 installed, very happy with it.
Does anyone know which button to use on the remote to record on sky though? it's the only thing I can't figure out.
Paul
Hi All,
Paul
I have sky on my beo4 press menu then 8 an r will then be against the programme you are going to record
cheers
malcolm
Hi Paul
I'm just having the same problem with my Beoremote 1 and Sky+HD on my BV14-55. Did you ever get an answer from anyone. Thanks
There should be an overlay menu (from the PUC), when you press Menu - this should show you which button/button combination to use.
