Hi I am just about to get 2nd hand b + o dvd1 , just wondering can I connect this to non b and o tv with scart ? Also my beo4 remote does not have dvd button on it can someone please tell me how I can set up beo4 to operate b and o dvd1 ?
Beo dvd1 connection to non b and o tv
You should be able to add the 'CDV' function to your Beo4, which acts as if it were DVD.
However, your DVD1 will not have its own IR sensor hence will not work from the Beo4 without being connected to a B&O TV. You can of course use the DVD1 front panel switches.
Guy
dELETED
Looks fine to me as long as the cosmetic damage is light!
Great cheers for that !I really dont think I can continue using £30 speakers with my beosound 2300!
