Beo 6 Battery Replacement
Hi
Does anybody know where i can get any battery replacements please for the Beo 6
B&O dealers can usually source them. Mine was about £40 in early 2019 if I recall. I did source a second made by a guy in UK by searching on here, but not sure if he still makes them. Unfortunately I can't remember his  details.
Beo5 & Beo6 use the same battery.
Stoobie
Exeter, Devon, UK
You can also, if you're handy, buy individual cells for about 6€.
Honestly they wont last as long as a genuine battery but for the cost, they're quite good.
