Beo 5 or Logitech Harmony?
Hi everyboby!
I have some doubts about the ablity of my Beo5 to control nonB&O stuff, as my decoder. My dealer told me that it was not a priority for B&O.
"Change your TVset" was the radical advice of my retailer... Indeed, my Avant is 4 years old 😂
I'd rather change my remote, which would cheaper, and because I love my current TV!!!
 Philips' Pronto are far too expensive, and I've discovered Logitech universal Harmony remote. The 1000 offers a touchscreen, advanced programing abilities, and not so bad design, although it's not comparable with the Beo5 one's.
Does anyone there have a B&O / Logitech experience, if yes, is it positive or negative?
Thank you for your feedbacks,
Laurent.
My installation :  Avant 28 dvd+ Beocenter 2+ decoder+ Wii, linked with a Beolab 2000. Beocenter 2300, Beocenter 9300.
There's also the Philips Prestigo range, much cheaper still - see here for fellow Beoworlders reports.
Thanx,
I've considered the Prestigo as well, but it's a pain to my eyes......
Laurent.
Well at least with the logitech you get the configuration software and online help if your devices aren't supported "out of the box". My pal has a Logitech (although he doesn't have B&O equipment) and the help/support service helped him to configure his device for non-supported equipment (sending new files via email etc). He was very inpressed.
It also does "macro commands" whereby a single button selection will configure the TV, satellite system, surround sound system etc to suit your requirements.
It suits his needs perfectly.
The Harmony will be a pain to your brain. At least avoid the 1000, you'll thank me for it.
You might want to consider the step up from Prestigo by Philips, Pronto, if you want a real high-function kit.
I'm very happy with my Prestigo, and I'm using it in the dark. Actually doesn't look that bad.
i have a harmony 880 -the best a/v purchase i ever made!
after some tweaking up front -it is flawless.
i would do some research though -they have limited beo functionality at least w/ the older (pre beo4) equipment -and perhaps w/ the later as well...
as your equipment is newer -you may be ok -but do research it.
I can't really speak to other universal remotes specifically, but I would recommend putting off any high dollar purchases until the Beo 5 is fully mature. The Beo 5, like the iPhone, is essentially a vehicle for software, which will undoubtedly change and mature with time.
Beyond that nebulous statement, though, we do know a few things:
3rd party communication is possible. It may be a full year before serious development begins, but it will. There is no question.
End-user access is coming. Again, this may be a while, but it is planned. At this point the Beo 5 is more a new concept than a new product, like the BeoMedia. As they mature, development will roll on more quickly and more comprehensively. Right now having programmed quite a few remotes, the software is remarkably easy for people who understand how the Beo 4 "works" (I don't mean what buttons to press, I mean literally what it's saying to the products). It's highly graphical and drag & drop simple. Like I said though, all the GUIs and dragging & dropping in the world doesn't make people understand the nuts and bolts of the Beo 4, which is currently what's required for anything beyond basic programming and channel icons. This will change though, just be patient!
Hopefully this helps. None of this info is really top secret, but it's also nothing that B&O want to put firm dates on yet.
Good luck!
relative to costs:
my harmony 880 retails for ~$299 in the states.
i got mine NIB for $109 on ebay...
the seller had other logitech items and may still be selling them -i'd have to look that up though -and i'd be happy to share if anyone was interested.
B&O have just released a big software update on the Beo 5, I got it and now all the stb-c commands are on the display so you don`t have to use the "menu" button. It also fixes a lot of other problems I`ve been told. Mine controlls my PS3 also, so I`m happy with it 🙂
Hello,
Doesn't B&O remote control uses a slightly different IR beam than conventional remote controls (I thought I read somewhere?) Are the Logitech and Philips able to be programmed to emit Beo4 compatible IR signals?
Thanks.
Beomud
