Beo 4 Repainting
How do you repaint a Beo4 ??
I have searched the forum, and cant find anything ? most Beo4 body's chip or get scratched, is there a workshop on how to repaint them ??, do you have to strip them back to bare metal ?
Ken
I have always used hammerite ( non hammered )... works and lasts
Also better Finnish when the surface is prepaired ..medium grade paper
Paint brush or spray ? Have you done many of these remotes ?
Ken
Spray is best ...a bit of an issue getting the battery terminals clear from the case of the remote ...just take care.
When you have the case, wire wool and gently remove any loose paint
Then just hang and spray about 3/4 light coats will do and allow 24/36 hrs for drying
I have a large section on the side that is bare metal, how can i fix this, or do I have to strip the side back to metal and repaint the side first, so that I get an even coat on the whole body.
Ken.
Just take it back to bare metal with a paint stripper then wash and dry ready for paint.
Thanks,
Ken
Have you got a Beovision 7-40mk5 ? Im looking for the Manuels ?
Strange that no one else on the forum has ever painted a Beo4 ?
Ken
not here but there is a dealer on ebay ....
https://www.ebay.de/itm/Bespoke-Bang-amp-Olufsen-b-amp-o-beo4-Fernbedienungen-Charakter-Print-Titan-12-/303239644703?nma=true&si=9V2X3oH7AlnP1JEWdUoBlny2WI8%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
good luck
Still no dealer thats ever repainted or touched up a Beo4 ?
Strange, maybe it was cheaper for them to buy a new body ?
Ken
