Hi all!
I have a couple of questions, I recently both a second hand pair of BL5 Serial numbers above 2XXXXXXX, had to replace tweeter and mid range on one of them. I also bought a Beolab 4 (the one with the V.Tape button).
Question 1: do I need a specific Bio 4 generation to run and setup the BL5s? I was able to choose option 1 to run my setup but I don't know if I will need seething also so I better het a newer version of the Beolab 4
Question 2: one of the speakers (right side) after minutes of turn them on stops receiving orders from the remote. at the beginning both speakers change volume at the same time but after a while can't change volume and even turning the speaker off. what could that be?
I'm afraid that may be I bought a Lemon fo speakers.
My setup is as follows:
Sony hires player model UHP-H1 connected via SPDIF to a Cambridge DacMagic Plus from there I'm running a hight quality digital cable SPDF to the right speaker (side selector as right speaker) and from that speaker to the left side speaker using a SPDF cable I have a sync cable between the speakers (inverted mini plug) and controlling ON/OFF/volume with the Beo 4
I ordered a Beosound core with essence remote to use controller instead the Beo 4, I order a couple of cable from Steve at SoundsHeavenly ( on there way ) but as for right know that what im using. Am I doing something wrong with that setup? what the speaker is not responding to the remote after a while?
