Hi Beoworld Forum!
After a long long time of searching i found a Beo4 Cinema with light function and i just can say its so fantastic to finally have the possibility to see the content of the display without switching on any room lights, especially when you have to use the soft buttons. I always had to count the numbers of pressing list to get to my desired function... Now its over :) But the problem i have is that the upper part of the keyboard (all buttons above the coloured ones from the TEXT row to TV row) are dark. That means the fiber optic cable inside must be broken at some stage. As i am familiar with that kind of stuff i had the idea to open the remote and fix the problem. The easiest way: calling b&o dealer and asking for service manual. Unfortunatelly not in this case... He told me there is nothing more in the system for that type beo4 (1162604). Now i really hope someone of you had a chance to save it and could provide it. The dealer just sent me the newest service manual, which i suggest will be totally different as the remote has a completelly different interiour. By the way i was thinking the Beoremote would solve my light problem in a way but unfortunatelly its not working with anykind of stb, or apple tv or ps3. So that was a disapointment as well, even if it is a brilliant design piece. I will never stop loving my good old BEO4 :)))
