BEO 4 - permanet Link mode
Dear All,
how can I switch the BEO4 into permanent Link mode (without pressen the Link button in the link room) ?
Thanks !!!
Config 2, 0, 0, 2
Works well, got one my own!!
If you press link after that will it go *out* of link mode so you can control the other devices?  Or will it permanently only control the link product after that?
Why use link-mode?
 What are the benefits?
I have a BV3 as master, BC2 as slave and BL3500 in a link room. Why would I want to use link mode for the remote in the link room?
I have a link room close to the master room. The Beo4 is so power full that it activates the link room by accident all the time. With the link room in opt. 4, I can control them separately. Very clever - IMO.
you are correct Christian, that is why I have the same!
