Hi, can the service menu be accessed via remote on a Bang & Olufsen TV BeoCenter 1 with sw 1.8?
Bang & Olufsen TV BeoCenter 1 service menu question
Yes it can..
In the MENU select SETUP then press 0 0 GO within 3 seconds you now enter the Service Menu
Do you need a pin code to access the service menu? As I'm looking at one on ebay, and when I asked them to access the service they sent me a picture of the pin code screen.
How would I obtain the master code for an old TV?
