I have just bought a pair of Bang & Olufsen P30 Speakers and I have no idea what amp to buy that will work with it. Ideally, it will have an audio jack socket.
The person I bought it from has described the wire connection as follows: "A female din connector is at the end of each speaker wire & they just plug into both speakers, there is no din at the other end of the speaker wire just the standard bare 2-wire so you can connect them to most amps."
Having no experience in buying amps in the past any help would be very useful, also bare in mind I am on a tight budget!
Thanks in advance!
