Carolpa wrote:
Note: Airplay works max 48kHz and 24bit; Core compatible
When streaming from the B&O App, the device acts as a DLNA server, Airplay is not used here. For the purpose of helping the OP, I converted an ALAC file (24/96k) to a 24 bits / 96,000 kHz AIF file, played it against a M3 and I had no issue.
@Antonius Robin Iriawan:
- have you recently installed something new on your device? Something that could conflict with the TCP port used for the DLNA service, 8085 here.
- are your AIFF files higher than 96,000 kHz?
Below is the M3 notification while playing:
{"notification":{"timestamp":"2020-10-22T07:55:07.563396",
"type":"SOURCE","kind":"source","data":{"primary":"music:2730.1200316.28725910@products.bang-olufsen.com",
"primaryJid":"2730.1200316.28725910@products.bang-olufsen.com",
"primaryExperience":{"source":{"id":"music:2730.1200316.28725910@products.bang-olufsen.com",
"friendlyName":"Music","sourceType":{"type":"MUSIC"},"category":"MUSIC","inUse":true,"profile":"","linkable":true,
"recommendedIrMapping":[{"format":0,"unit":0,"command":145},{"format":11,"unit":0,"command":145},{"format":11,"unit":0,"command":148},
{"format":0,"unit":0,"command":150}],"contentProtection":{"schemeList":["PROPRIETARY"]},
"embeddedBinary":{"schemeList":[]},"product":{"jid":"2730.1200316.28725910@products.bang-olufsen.com",
"friendlyName":"M3"}},"listener":["2730.1200316.28725910@products.bang-olufsen.com"],"lastUsed":"2020-10-22T07:52:24.220000",
"state":"play","_capabilities":{"supportedNotifications":[{"type":"SOURCE","kind":"source"},
{"type":"SOURCE_EXPERIENCE_CHANGED","kind":"source"},{"type":"PLAY_QUEUE_CHANGED","kind":"playing"},
{"type":"NOW_PLAYING_ENDED","kind":"playing"},{"type":"STREAMING_STATUS","kind":"streaming"},
{"type":"PROGRESS_INFORMATION","kind":"playing"},{"type":"NOW_PLAYING_STORED_MUSIC","kind":"playing"}]}}}}}
{"notification":{"timestamp":"2020-10-22T07:55:07.564458","type":"NOW_PLAYING_STORED_MUSIC","kind":"playing",
"data":{"name":"Space Oddity","duration":320,"trackImage":[{"url":"http://<iphone IP address>:8085/media/artwork/3704425888912782282","size":"large",
"mediatype":"image/jpg"}],"artist":"David Bowie","artistImage":[],"album":"","albumImage":[],"genre":"","originalSource":"DLNA",
"playQueueItemId":"plid-1481"}}}
