Bang & Olufsen App 3.8
Version 3.10 out in Testflight.
The rather confusing WiFi symbols are back.
.... but aligned!
There is also a new Diagnostic section, promising, but confusing as incorrect status are reportes .... they warn it is a beta!
WIDGETS are gone
Numerous old and reported bugs/inconvenience are still there, as usual.
mbolo01 wrote:
.... but aligned!
WIDGETS are gone
Same thing for my setup - except that Widgets are still present and ok.
Best regards
Dyssegaard
Thanks for sharing. I restarted my iPhone (XR latest OS) and Widgets are now back
What I would really like to see is the option to adjust the level of specific sources to obtain the same volume level across sources. It surprises me that others aren't really annoyed at having to reach for the remote to lower the volume for TuneIn and Radio sources and to have to raise the volume of turntable sources. It would seem like a simple feature to add.
I would like TIDAL Support in the App and native support.
Is there any reason why changing the dot size in Beosonic is now back for headphones - I’d thought it was removed due to a channel imbalance issue?
More critically thought since 3.9 (on iOS) the default ‘optimal’ setting now has the dot slightly enlarged which is a complete change in sound signature from earlier versions. Was this intentional or a QA problem?
This is with the H95, but I don’t know about it he rest of the headphone line.
Would like a "search" option in DLNA for the app.
Just like "VLC for Android". B&O already developed a DLNA search option for Beosound Moment. It feels hopeless to have to being forced to scroll down your entire music library manually everytime.
I may sound like a broken record but It’s really a shame that B&O coders are not able to simply retrieve the album cover from a B&O product when AirPlay is the source (and the cover image is available). With a media_player card in Home Assistant it is definitively possible so why not with B&O app itself ???
BS Core playing an AirPlay source in HA:
Same from the B&O App 😕
Changing the dot size has always been there for some headphones (i.e. H9 3rd Gen).
Now btw in version 3.10 (which is currently in beta, I'd expect it to go to stable in a week or two) they've fixed the bug which defaulted the Optimal (or Signature, in some other devices) sound preset to having a slightly enlarged dot (bug introduced about two weeks ago).
With the H9 3rd Gen, though, the custom preset is still not always saved to the headphones (sometimes it automatically reverts to Optimal, even if you set it to another one).
