Bang & Olufsen App 3.8
Hi all
New beta is out with a configurable widget for controlling your setup. Touch to join, Beosound Shape sound modes and other options. We no longer open the app, but send the command directly from the widget, based on your feedback this was what you were looking for. You will find the configuration here settings->widget, please let us know what other features you would like to see here. Furthermore, we have released a radio service for the Beosound Balance, you can now assign radio stations to the favorite buttons without using Google.
Best regards
Thomas, Bang & Olufsen
Great, I would have used icons instead of text to represent the widgets, here is a suggestion:
BS Moment TouchtoJoin is missing, why?
New feature I would like to see:
Standby
Standby All
Mute Sound
And the Controls of the Moment doesn't make sense.
Hard te differentiate between product because of the lengths of the names. So Mbole proposition could be a solution.
The control button doesn't lead you to to setting of that product but opens the app
The Music tab (Deezer/DLNA) is no longer working, app is freezing.
works for me though
Carolpa wrote:
works for me though
Do you have one or more DLNA server?
Idea: make the JOIN widget a toggle button. If the product is already joined, release it and put it in stdby, otherwise let it join other devices.
nb: the order of devices in the app is correct again. thx for adjusting
