Bang & Olufsen App 3.8
Switching from one device to another takes just 2 taps. Tim Login to view imageTap on the device name Login to view imageList of devices appears. Tap on the one required. Login to view imageWill they ever incorporate volume control functionality in one place? At present I have to leave the Core, open BL90 to change volume and the exit and go into Core. Very tiresome.
Hi mbolo01
This was a fix of some crashes we observed in the market. We made what we called a hotfix, with some very small fixes. For some reason the Apple review time is much longer for test flight than with a normal release. Hence, in these situations where I put them into review at the same time, the official version will be out first. You should have it by now.
Br
Thomas
Got you thanks.I’ll take this parameter into consideration when it happens next.For some reason the Apple review time is much longer for test flight than with a normal release
I agree with you about the spacing and tint. Further more I wonder why there are WiFi symbols on my multi room products as they are all cabled to my network? Login to view imageThe Bluetooth icons only shows when the product is connected - so that is ok. Login to view imageI would have given more space between the WiFi and the Multiroom icon, and I would have set the same tint for bothBS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Dyssegaard
