Some are still missing Login to view imageMissing icons fixed :
Hi guys
I have deployed an update fixing the alignment issues and added a fallback icon. Unfortunately we do not have icons for the older products yet, we will add them as they come. The ordering is the same as in the app but this is just the first version. We will make a lot of tweaks on this in the future based on customer feedback.
Hi guys
Great.
When will you fix the strange looking multiroom icon in the iPad version?
/Claes
Hi guys
Hej Mr Andersen,
I might be the only one (?), who would pledge for a possibitity to choose which icons = which products to show in the widgets view.
That goes for the products view in the app itself as well.
But I’d still like to know if that is on the roadmap?
Let people decide, what to see, make it costumisable.
MM: Yes, we will make it configurable
Claes: Could you post a screenshot of the Beolink icon?
The widget does not work on IOS 12 devices.
It shows "loading impossible".
Kind regards,
Yann.
From the iPad Login to view imageClaes: Could you post a screenshot of the Beolink icon?
MrAndersen: I raised this multiroom icon misalignment a while ago to B&O support and it is part to the issue track list I’m maintaining in this forum where you should find the associated case #Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2From the iPad
