The widget doesnt show up as an option on iOS14 (public beta), which I guess you may be aware of.
On my iOS 13 devices, it does show up, but some of the product icons have no images, as below
- A9, BS2 show icons
- Avant MK1, BV12/BS4, and Moment show blank tiles
With iOS 14 the Widgets can be small, medium or large. It would be useful if, for the medium / large versions especially, the widget also shows what is playing.This will probably need to be limited to (what is playing) on the most recently activated product. Otherwise the widget as it is just works as a shortcut to the app. I know Apple widgets are a little restrictive in how interactive they are, but displaying the now playing info in the widget would make it more useful. Given that most of us will move to iOS14, I'd definitely think about how to make the most of the different amounts of information that can eb displayed with the small, medium, large options going forward.
In addition, I'd also suggest adding options to the long press on the app - if I long press the Tidal app icon, there are options for Now Playing and Playlists, Deezer long press shows a Start Flow option too. So if now playing info isn't / cant be added to the Widget (as described above), then why not add options (as Tidal have done) to the long press option.
Anyway, my suggestions for what they're worth.
