Bang & Olufsen 2.6.3 is ready to test on iOS
1. DLNA Album art ok for me (M5, Core, BS 1 were tested, no integrated setup)
3. Loop issue is supposed to be fixed by product updates if I remember well
Thanks for the feedback. I will look at the other sources. Shuffle repeat needs a product update as well, I will try it just the same for DLNA.
The issue with album art was that we use https and that didn't work for DLNA servers. We now use http and that fixed it in our setup. We have in the past seen that the products sometimes are behind when sending the meta data. If you open and close the player, is it still wrong?
I have just tried the DLNA playback again on my M5. If I step through the songs the album art is blank. If I then close the Now Playing view and opens it again the album art is updated correctly.Thanks for the feedback. I will look at the other sources. Shuffle repeat needs a product update as well, I will try it just the same for DLNA. The issue with album art was that we use https and that didn't work for DLNA servers. We now use http and that fixed it in our setup. We have in the past seen that the products sometimes are behind when sending the meta data. If you open and close the player, is it still wrong?
I do exactly that on my M5 and I can step through songs on an album and the album art is always shown.
Interesting observation, we will try this. The symptom could imply a product issue, but I hope not. Then it will be harder to fix.
I have tested the scenario on both my Core and M5 and had no issue.I’m not in an integrated setup and I used Minimserver in that test[edit] the only issue I have seen while playing the test scenario is the progress bar not being updated properly and staying filled independently of the real track elapsed timeI have just discovered the following regarding the DLNA cover art issue
@Dyssegaard tried it with 4 tracks from 4 different albums with shuffle and it worked on our Synology. What NAS are you using?
