Hello guys,
I need your expertise in order to see if I can add more bass to my system without spending a lot.
I own a B&O system formed from 2 x Beolab 4000 speakers ; 2
& Beolab 6000 speakers and a Beosound Ouverture unit.
The system has a great sound , but I do feel the lack of bass when I raise the volume (due to the ABL system I suppose). I wanted to know if I can connect a Beovox CONA subwofer to my system using a Beolink converter or any other equipment ? I looked at the Beolab 2 prices but they are over my budget right now :( and I can't afford to buy one in the next couple of months . Do you think I'll loose the sound quality If I use the CONA subwofer ?
Any advice from you will be much appreciated as I didn't hear the sub and don't know the sound quality for it.
Thanks a lot,
Stefan
