MM,
Problem is B&O doesn't deliver to my country.
I have a Sony 75" X940E ( there was no HDR beovision back in time ) which I really like.
So far the pros and cons of each setup is :
Beosound Stage Pros :
- Easy to setup
- Less expensive
- Easier to replace
- Dolby Atmos , Airplay 2 and other streaming perks.
Beosound Stage Cons :
- Difficult to integrate in home automation systems ( Crestron specifically )
- ARC doesn't support True HD 7.1 and DTS-MA lossless and very few TVs support eARC
The Celestial + Palatial ( with magnetic grills ) + Subwoofer + Surround AMP will cost around 15,000 USD which is almost 10 times more than the stage however, it's a 5.1 system.
Pros :
- Can be integrated with all automation systems
- Lossless audio
- Lower bass extension obviously because of the subwoofer
Cons:
- Very difficult to replace or upgrade ( drilling, size, etc.. )
- Expensive as noted above
- More power and space consuming
- No Atmos support
Looking at the cost alone, I'm not sure if the $15k system will offer a much more enjoyable movie experience .
