B&O Remote App + Beolink NL/ML Converter surprisingly controls ML Products
Much to my surprise today I have found that the B&O Remote controls all my main rooms ML products.
I recently installed a NL/ML converter to connect a Beovision Horizon to my ML sound sources. That is a BS9000, plus a BV7 which is acting as a master for video sources.
To my pleasant surprise the app now completely controls the BS9000 and the BV7 including the set top boxes connected, aux ports and standby.
I suppose this is old news to some. Though, on a search of the forum I found no reference. So I wondered if others were aware of this capability?
Beoaus.
When you say B&O Remote, do you in this context mean B&O app?
The apps name on my iPhone is BeoRemote...
Do you have the BLGW as well?
No BLGW at all.
Within the "BeoRemote" app you simply select a source, mine are; TV,V.Mem,DVD2,DTV,DVD,DTV2,CAMERA,V.AUX2,PC,RADIO,A.MEM,N.MUSIC,CD,N.RADIO,A.AUX.
Then a simple menu structure with multiple pages are displayed to control the source above. This includes; volume, program control, coloured button control. I can change channels on the TV, record programs, listen to CD's etc.. In link rooms
Quite the find...
Additionally I can remove some of the unused sources or rename them via the converter. No Macros though.
Beoaus.
Beoaus.
My memory is fuzzy but I seem to have had this up some time .... and found it not so useful despite its simple interface.
So I am not surprised as you were ... except prompted by you I took a close look and found I can access my new Core and cause it to play Deezer on the BV8 very simply !!!
No ability to manipulate the contents of the playlist that is the role of the other App ... but to simply initiate background listening with a simple click it’s marvellous !!!
Hi Beoaus
Thanks for the tip!
Leo
That is the good old BeoRemote app.
The sources from your NL and ML (mapped via the converter) will appear there, when you choose a source to control in the main screen.
Is the speakers Connected to BV7 or BS9000? How did you set the NL/ML converter up... as v.slave?
Søren
As I just got my Converter today, I am very interested, how you´d set up the converter for using the remote app... So please more details...
Kind Regards
Tom
