B&O Radio Migration Available now
Christian today posted a bunch of articles / links on the Discord server, explaining all the changes to functionality (explains change in my Buttons, alarms, one touch operation etc etc)
Here are a few of them, though its probably easier to read his long Discord post.
https://support.bang-olufsen.com/hc/en-us/articles/8716445177745
https://support.bang-olufsen.com/hc/en-us/articles/9940012232081
https://support.bang-olufsen.com/hc/en-us/articles/9940005580689
https://support.bang-olufsen.com/hc/en-us/articles/10855168034833
https://support.bang-olufsen.com/hc/en-us/articles/10275507993489
My Eclipse now has B&O Radio working and available from both the App and Beoremote. Just had an update to the app which seemed to make it work.
Paul
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Gen 3.
Christian today posted a bunch of articles / links on the Discord server, explaining all the changes to functionality (explains change in my Buttons, alarms, one touch operation etc etc) Here are a few of them, though its probably easier to read his long Discord post. https://support.bang-olufsen.com/hc/en-us/articles/8716445177745 https://support.bang-olufsen.com/hc/en-us/articles/9940012232081 https://support.bang-olufsen.com/hc/en-us/articles/9940005580689 https://support.bang-olufsen.com/hc/en-us/articles/10855168034833 https://support.bang-olufsen.com/hc/en-us/articles/10275507993489
Thanks for pointing towards the explanation, that helps to understand. Unfortunately I cannot operate according to the hints how to toggle between radio services, because it is not available in my app.
Rolf
After an update of the app (on iPad) I am also able to use B&O radio (using Millemissen's tip to rebuild a list of favorites from the bottom up). Playing my stations seems to work well from Core through BLC onto MasterLink, apart from one (quite annoying) change! - I now MUST start radio from the app. Radio with not start with the (IR) remotes. Only after starting radio from the app, I can use Beo4 to select the station or move up&down. The Core keeps playing radio after I switch (my BeoLink Active) off with the remote, but stops when I want to start RADIO (again) with Beo4. Has anyone else such a set-up (and issue)? My Core is at software 2.1.5087122855122.
In the other thread (https://forum.beoworld.org/forums/topic/new-software-edge-shape-core-bs1-bs2-a9-mk3-4/) I wrote that I corresponded with B&O about a similar problem (still with Tunein). I will see if there will be a change with any software update and let you know.
I am able to toggle between B&O radio and TuneIn, so for now I will use the latter that still behaves a bit better and does not switch off radio when I use the RADIO button Beo4.
Have a good evening!
Rolf
@Rolf2 This setting is also not available in my app either!
@Sandyb I have read what is in the links to the B&O pages.
For those of us, who are not on Discord, what is in the Christian posting there, that is not part of what the B&O pages explain? Anything important?
apart from one (quite annoying) change! – I now MUST start radio from the app.
did you change your BLC settings (IR Mapping") accordantly?
I'm able to migrate, but when I chose a radio, my Beosound Core says this source isn't supported.
It says I'm on the latest software.
