So just to stop the na sayers ... sorry I have actually other things to do
here a link to the document which we sent to B&O showing them the issue ... btw there is also a similar pic in the V1 thread .. showing the same type of damage..
https://dl.dropbox.com/u/5652169/PLyV1_20120521_001.pptx.pdf
When this was received by B&O they stated its not their issue... that it was the user that caused the issue .. and that B&O QA was perfect !...
Now as previously stead the Dealer is facing a 8 out of 8 damaged units on his hands ...
based on the last units in my case being unpacked in front of my eyes and each having the same issue (albeit in different locations) it can not be a USER issue..
Actually looking in detail at why the problem is its is easy to identify the exact root cause .. which is when you take it out of the box based on their instructions, the back and front pieces are made to come in contact (could also happen due to vibrations during shipping), thus damaging the paint finish..
that said ... this is targeted at the take away and install yourself ... hence play .... if it is so easy to damage even following the instructions ... that is in my eyes a lack of quality of experience ... and a lack of quality controls as this should have been picked up and address early in the testing and fixed by the inclusion of a 10cents piece of paper or cardboard which would stop both sides touching till after the stand or wall bracket has been interred (as this completely stops both surfaces touching as you would expect)
So great that all you what 2 subscribers here don't have problems, but at least 8 V1's from 5 different clients, all from different production weeks have the same thing here in Germany !...
If i am paying a premium price then I expect them to not destroy the experience out of the box, in the first few minutes (google on why out of the box experience [OBE] is the most important point of brand equity).. especially when it is so easy to fix ... or when a client takes so much effort to help them improve, only to turn around and blame the clients and state "We are B&O we are perfect, and our QA is perfect" [paraphrased as described to me by the dealer]] and its not their fault .. in such cases this can only mean that their quality is going down hill.. QED..
@mike enough proof now ... "Since the author of this thread has failed to show any pictures" ... or are attacks the correct thing here on this forum ?..
