I'm trying to test my "Loudspeaker Switch" When i turn it on, it automatically goes to channel 1, but in order to change channels, you need to connect an IR receiver.
Now according to the archieved forum "The IR looks identical to the MCL IR but it’s not the same. It has an 6 pin DIN lead, but only pins 1,3+5 are used, number 8712009"
From: /forum/general-discussion-and-questions/bampo-speaker-switch---how-do-i-use-it
Now i do have an MCL IR and an DIN cable that fits, but i can only find IR pinouts for DIN connectors with more pins.
Can someone tell me to which pins i should connect the wires from the MCL IR? i suppose it'll be the Green: 5v, Brown: ground? and White: Data. But correct me if i'm wrong!
Login to view image
Login to view image Login to view image
Login to view image Login to view image Login to view image Login to view image
Login to view image
Login to view image
