Stoobietoo wrote:
What I now need is a way to turn on the LG TV. If I can swap my round B&O IR eye for this transceiver and get it connected to the BS3 and Raspberry Pi maybe I can use it to turn the TV on and off with the Beo 4? Do you think that possible?
Theoretically possible, but in practice probably quite difficult! (Having thought about it some more!)
Main problems:
- The IR transmitters in the Transceiver are outputting at 455kHz - incompatible with the LG TV if done directly.
- The only signals that I am aware of that the transceiver has been designed to transmit are return signals for 2-way remotes such as BL5000/7000 and MCPs, plus LIGHT commands (and associated numbers, up down arrows, STOP command etc). Even if you could get it to transmit these signals, you would need something to convert to a signal that is then understood by the TV.
- Although the two-way transceiver has an on-board microprocessor, it only has one external data connection (the white wire) which is used for data in both directions. The challenge would be to work out how and what data signal signal to inject. You may have to introduce a MCL2A or MCL2AV into the setup to at least provide a box that understands datalink, and then convert from ML to datalink somewhere else.
