B&O Beocord VX7000 Compatibility with a Beovision LX4500 TV
Question time as I can't seem to find an answer lol.
Will a BeoCord VX7000 work properly with my BeoVision LX4500 TV, particularly when it comes to remote control operation?
I’ve heard mixed things online, so I’m hoping someone can clear this up.
I have both a Beo4 and a Beolink 1000 remote. From what I’ve read, some later VX7000s apparently only work with the Beo4, which seems quite unusual for B&O. I’m not sure whether that information is actually correct, as pretty much every bit of B&O kit I own from around the same period works perfectly fine with either remote, apart from my Beosystem 5000.
What confuses me even more is that the much later V8000 VCR and even the DVD-1 are known to work perfectly fine with the LX4500, including remote control operation.
So why is there such a grey area surrounding the VX7000’s compatibility? Especially considering it was released only about a year after the LX4500 was discontinued.
Has anyone actually used a VX7000 with an LX4500 and can confirm whether everything works as it should, including play, stop, rewind and fast forward using the TV’s remote? Or would I be better sourcing a new V8000 unit instead?
Picture of my setup below lol
Have a look at this thread - I see no reason to doubt Peter's answer about specific type numbers:
/forum/general-discussion-and-questions/beocord-vx7000---remote#post-1892562
As other's have stated,the machine will function,but may exhibit odd behavior depending upon the level of software on board.
B&O continually updated the software to include new functions and to ensure compatibility with newer product,but of course not alway's backwards compatibilty.
The earlier VX5500 should be a plug n go solution.
I have a spare one up for grab's,which was functioning before storage.Free to you for shipping costs,or collect if local-ish?
Warwick.U.K.
Nick
Agree Peter's post is the right info on this.
To test out my web port of the link, I got this response from the 1997 Great Britain Rulebook:
************************* VIDEO SYSTEM SETUP **************************
Beovision L 4500
Beocord VX 7000 (VTR 1)
Connection Video
Connect the VTR 1 to the AV 1 socket of the TV-set using a fully
specified 21/21-pin A/V cable (RGB cable).
Connect the aerial to the aerial input of the VTR 1.
Connect the aerial output of the VTR 1 to the aerial input of the
TV-set using a coaxial cable.
Selecting option on the TV-set
Option: OPTION 1.5 (Factory setting)
Press: STANDBY PICTURE 1 STORE
PICTURE 5 STORE
Programming the setup
VTR Setup: VX 7000 type 461x
Press: V.TAPE MENU 0 0 PLAY
Select SW-version" med PLAY
Press: TURN (BL1000 MK1/MK2)
SHIFT PICTURE (BL1000 MK3/MK4)
MMI 1: is for Beolink 1000
MMI 2: is for Beo4 (factory setting)
Press: STANDBY and cut the mains supply to the VTR for 10 sec.
After connection to the mains supply the VTR will function
with the remote control selected.
Note!
All products must be interconnected before they are connected to
the mains
The Beovision must be equipped with software (S/W) 2.1 or
higher, part No. 8341713.
The VTR cannot playback the sound of NTSC tapes in stereo.
If the VTR modulator frequency interferes with other signals in the
UHF range, adjust the modulator frequency by means of the screw
on the rear panel of the VTR.
The recommended distance between channels in the UHF range is
16 MHz.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beolink 1000
The following remote controls may also be used:
Beolink 7000 (2-way IR setup for the A/V system)
Beolink 5000 (2-way IR setup for the A/V system)
