Might be a while ago I did use the B&O App but noticed that I can't init Deezer from App anyomore to start Deezer play via the Moment; when was this changed?
B&O App and Deezer via Moment
Are you sure you are logged in to your Deezer account on the Moment? Will double check it but Iām able to play Deezer on my Moment on the B&O app. You must first select the Moment as active product in the app and then select music and play from your Deezer account.Might be a while ago I did use the B&O App but noticed that I can't init Deezer from App anyomore to start Deezer play via the Moment; when was this changed?
Yes, logged in as I'm currently playing from Deezer and only time I'm able to interact with Deezer is what is in the playlist when checking the App. But, I can't call Deezer from the app and I also remember that I previously had to login also to Deezer via the App which I can't find or locate if it's been shuffled around š
In the App go in settings (profile icon), Music and DeezerYes, logged in as I'm currently playing from Deezer and only time I'm able to interact with Deezer is what is in the playlist when checking the App. But, I can't call Deezer from the app and I also remember that I previously had to login also to Deezer via the App which I can't find or locate if it's been shuffled around
Super - Found it! Totally missed out that it was under the profile icon; but sometimes ones is looking to hard that one doesn't see the obvious things š
This demonstrates that the profile icon is not a good choice compared to the previous cogwheel, imho.Super - Found it! Totally missed out that it was under the profile icon; but sometimes ones is looking to hard that one doesn't see the obvious things
Lol! So something did change then since I was as you say looking for cogwheel or something more of inviting to configure something and clicking on the Moment to find something there....
Register to access the forums, reference material, and exclusive member benefits ā including our monthly prize draw.
