The procedure is complete. It required a bit of drill action (acting as a grinder) on the inside plastic to allow the huge magnets to fit, but it didn't compromise the enclosure.
At first the sound was more accurate but didn't have that "edge" the Penta's seem to be able to do.
Then I realised by removing the last part of the mid-range crossover I had shifted the phase 180 degrees. I reversed the polarity of the leads and ...
β
I would love to pitch these against some 5's now. I actually reckon they'd win!
I ended up going for the FRS8M's instead of the less sensitive model. The other ones have a real flat response, less power handling and would have fitted straight in, and my Penta 1's use a 3.3ohm reduction (the 2 & 3's use 2.2ohm) so the M's looked the better bet.
Incidently, the original mount brackets for fitting the original mid-ranges fit perfectly without modifcation. A nice surprise.
