A while ago I contacted Peter from this forum thinking my 70's 3800's were a match for his Pentas. I was wrong. At anything other than low volume the Pentas rock. They rocked so much I went and bought some. I still have them, and consider them to be better than anything else I've heard (I've not heard the 5's though).
Of course the problem is driving the buggers at high volume. I disregarded the optional beolab 150 and 200 because it's class AB, the transformers are known to melt over time, and it's just plain old technology. I bought a Cambridge Audio amp and drove at a maximum 100W. Something was missing.
I'd tried a Tripath Class T amp and was blown away with by the clarity. But I needed 150W of Class D/T. No I can't afford B&O's latest Active stuff, and anyway, the Pentas are still considered by many to be the best speaker design they've made. It would be a shame to get rid of them.
Solution
In a couple weeks I will show you how to upgrade the Pentas so that you can bin the powered amp if you have one and install two B&O IcePower ASC 200's. The panel is replaced with a simple dual colour LED, and the board snugly fits between the crossover units.
I've measured it and done the research, I'm just waiting on the boards. I have a supplier doing them for just $235 delivered.
So bookmark this thread because if you have a pair of Pentas and want audiophile defination you'll want to do this mod!
You will have 150W of Class D power, the same series of modules that power B&O's latest stuff, and it'll cost you no more than 200 quid.
Specification (for driving 8ohm pentas):
IcePower, 81% efficency
150W 10% THD (penta max rated volume)
130W 1% THD
100W 0.001 THD
Fully thermal & overload protected.
Automatic standby and wakeup.
How-TO
Coming soooooooon :)
