I've (almost) finished my first 'beolab RL7000' 🙂 (= RL7000 + ICE200ASC).
There's a powerlinkconnection and a powersupply added at the rear and a led to the front (behind the speakercloth)!
The ICE200ASC is next to the crossover. The caps of the crossover are also updated. I used Audyncap this time. Just because I could find most of the correct values in their assortiment. Only the 27uF was a problem and I made that one from a 22uF and a 4,7uF. The 22uF is hidden under the crossover.
I've taken care to separate all the cables to avoid interference. Mind the cable to the right. This one goes to the bicolor LED. I used a shielded 4wire cable (used for telephone) for this one. I used the same cable for connection from the powerlink to the ICE200ASC.
The cable from the ICE to the crossover is the original one, but I twisted it.
The only problem left is the autopower on and off. I connected the 'speaker on' from the powerlink to the 'signal sense' of the ICE, but that's no good. I'll try the 'Auto_on/off' next week.
Mind the little green led behind the clotch. I used a 3mm bicolor LED. Therefor I drilled a 3mm hole through the chassis. A nasty job to avoid touching the cloth, but I succeeded. 🙂
So next week the Auto On/off, the other speaker and next month the foam rot 😭.
And for the sound.... Well I only modded one speaker, it has foamrot and it's till burning in, but the sound feels relaxed and enough power to swing the RL7000 😐.
Kind regards
Joost
