B&O iPhone App Launched TODAY!!
stefan wrote:
Open Beolink - press Settings - press Done - press "i" - press Demo mode.
Hope this helps.
Stefan
Thanks Stefan, if I press 'Settings' it turns blue and I can access the settings menus. After pressing 'Done' and returning to the main page pressing 'i' does nothing, it doesn't change colour and nothing happens.
A 'Searching...' message is constantly displayed above 'the 'Settings' box and that's about it!
Thanks again.
Mine does the same! 😁
I was unable to get it to work but managed it by pressing i whilst holding the settings button down
I think it just depends where you put your finger, it seems the sensitive zone is a bit off to the top left of the icon. If you click on the icon in the center exactly it does not work all the time.
Thanks Phil, I take it all back!! That works.
Darren's method worked for me! Does it actually do anything? At work so no B&O! I take it you need the MLG to receive the signals?
No idea as I still have all my B&O in storage :( Believe it needs MLG to do anything
Yes you need the MLGW.
A 'simple' accessory that would receive the signals from the B&O iPod app and convert these to those compatable with B&O products would be nice, but I suppose this is what the MLGW does! I know little or nothing about the MLGW other than its price, so can't comment further.
Bang & Olufsen BeoLink for iPhone: Tutorial for installers
Link
Informative but long.. Specifically Iphone from ± 42 min 30 sec
