B&O iPhone App Launched TODAY!!
BeoLink the new iPhone App is available to download from the itunes store today!!
Now all you need to do is rush out and get a MasterLink Gateway!!
I'm off to program mine now! 😐
more info:
Got it!!
Pretty cool, but no point getting it, I'm not going to spend ~2000e to get it working. 😁
There is a demo mode, so it is worth downloading it, just for having a look.
It is a very cool app.
The clever bit is that they use gestures, so you can use it without looking at the iPhone screen, for the most common functions.
(The less clever bit: no 2 way display on the remote, no BM5/BS5 playlist navigtion on the phone, no TV channel list/logo, but I am sure that'll come later)
p.
Go on - and stop you buying a beo5? I don't think so! 😂 As I said before, this is a nobbled application - no doubt some clever chap will do an unofficial one that will work everything properly at some time!
Well, if you don't buy a Beo5 but buy a 2000 euro MLGW instead they win...
Downloaded the App and played with the demo mode... The typewriter sound when pressing a button is just sooo annoying! They could have at leased used the sound of the Beo5 for that! The gesture controle... don't know.. Would need to use it in real life in order to make up my mind... It's a good start though.
Sounds good !
MLGW and a Beo4 could control anything in the house which receive IR or RF codes ?
Mat
have been working B&O via iPhone using control4 for some time now. we work CCTV, lighting, iPod dock works great!
