B&O in comic drawing, I don´t get the point
Hi, found this in a Swedish newspaper. I don´t think it a Swedish comic strip, maybe German?
Guy in green: "How do you open it?"
Guy in red: "I've forgot ..."
Box below: "If Bang&Olufsen made cars"
Anyone?
I guess they are saying two things
1. B&O units are usually (?!) black shiny and rectangular -- (OK, true of my Beosystem 5000 units)
2. how to open them is often magical (also true of my 5000, but also thing of the glass doors that open on approach, or the DVD player of the BV7 which is invisible, etc, etc)
Maybe it's a sly dig that B&O is hard to operate? (It's not)
I have a friend that likes to joke that B&O is unintuitive, unobvious and basically hard to use.
Hi
I have seen that strip somewhere, but forgot where.
I can understand your friend, but not as a joke. I find that B&O are quite unintuitive and hard to use. At least nowadays compared to User Inteface in an iPhone for instance. Maybe they had good user interface once upon a time ( I do not know). After a couple of years of using B&O there are things that I do not dare to try. One example would be to change treble or bass in the kitchen. If I did that I would have no idea what I was doing, since there is no graphic showing how much I had changed in one or another direction. And if I have changed the treble or bass, how would I get it back to neutral again. The result is that I do not dare to try.
No, the strength in B&O is definitely not the User Interface, it is looks, sound and mystique.
B R
Clakke
Somewhere on this forum recently, and of course possibly in a newspaper...
It's by Wulffmorgenthaler, and they are Danish, so they probably know what they are implying here - I'm not so sure myself either 😂
Oops, sorry for that. Missed it on this forum.
They only thing I hear from people not having B&O it's the usual "overpriced Philips". Not that it's just a black box without user interface.
Anyone?
Think about the Beosound 9000 if you never saw B&O before...
How would you even turn it on???
Craig knows the answer to this 😂😂😂🤒
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Hahahaha! 😂
