B&O Beocentre 5000 parts required
Hi All,
A second post on the same subject.
I have recently aquired above mentioned unit. I still need a couple of parts, 1. Hinge for the metal cover on the "spring loaded side" as its worn and the cover slips off. 2. Replacement plastic record deck cover as the original has snapped all its plastic hinges off at the spring.
 Any advice or information on the parts etc would be much appreciated, especialy if you have them and I can purchase them!!
Many thanks,
Boots
Just got back after being away for the weekend. I still have the parts if you want them!
Simon
