Greetings fellow B & O members,
I bought a recent pair of B&O 8000s for almost nothing. One has a slight problem that I am going to attempt to fix myself, but first I have to get the base off. after unscrewing the main nut underneath the base, I discovered a brass insert around the threads of the post and in the base. The base will start to unscrew a few turns, but turns around the brass insert. After unscrewing a few twists, the base firmly stops and will not come off any further. I am afraid to force the base because I don’t want to screw up the inside threads of the brass insert. Should it just screw all the way off or am I missing something? These are MK1 I believe.
Any advice would be greatly appreciated!
any advice would be greatly appreciated!
Thanks,
Mattybang66
