Balance versus 2 A1s?
I have also used the A1 (first gen) stereo paired in various places on the go. For the size and price they sound extremely well. If you place the A1 on a strategic spot near a wall or in a corner the performance is even greater. Line of sight was a must and max distance between the two A1’s rather limited.
P6 was even better in stereo, two extra drivers then compared a set of A1’s and a lot more body. You can upgrade to those as well !
what would be cool if B&O makes some kind of bluetooth hub/router so you can use let’s say 10 different A1’s /P6 ‘s wireless for a super funky mobile cinema experience. 😁
